purk
- Sep 26, 2001
I Just finished doing the same thing but used DH-LABS OFH-20 ($12 for 2 meters on eBay) (Silver plated crystal copper wire). The stage is twice as wide, depth has improved a lot as well Transparency/Separation is amazing vs before with stock copper wire. This is just 5 minutes in. Loving what I'm hearing. I'm also loving the treble refinement.
I just did the 4 wires that come from the 4 Sony Capacitors to the 4.4 Jack. Didn't touch anything else (I don't think it's necessary.
This is with Hi-Res Streaming off...can't imagine how wide it'll sound with that turned on.
Listening to Khalid - Bluffin', can't believe how massive the sound stage is. Almost sounds Binaural now. This is worth doing fellas. Definitely time well spent.
If you're going to attempt doing this, the trick is to carefully remove the rubber cover but especially the metal plate that protects the internals without damaging your DAP.
It''s like going from a 2.1 system to a 7.1...still testing songs I know From Micheal Jackson to Yuna, Khalid... I'm like wow...that's a massive soundstage.
I think i just made my self an NW-WM2Z
It's Def worth it.
Awesome work guys! Do the wires to the battery mod will increase the sense of dynamics and a bit of slam and will make this player nearly on par with the 1Z. Yes, completely agreed on the soundstage and sense of resolution. I didn’t come up with this mod by the way. @Whitigir Inspired me to do this mod. Yes, releasing those metal clips was a bit*h.
