I will say the 650's power hungriness does make me want to pick up a balanced cable for it. I need to put the volume at nearly 75% for it to get to "headbang" levels.
You're a WILD MAN!
I am pretty cautious about where my volume is, but sometimes you just want to turn it up high and punch out your walls in the room, you know what i'm saying? (figuratively and close to literally)
So does driving headphones balanced make no sound improvement over unbalanced? I continue to get conflicting answers.
Understanding Balanced, versus single ended
Hey Rutter,
there is a lot of confusion about this topic so its understandable that you cant get concise answers all the time.
-Like the others mentioned, when running a headphone balanced it was my understanding that it will be able to have more power output period. Power isn't everything when it comes to amp design, since control of the driver is immensely important in addition. Some amplifiers that have single ended and balanced headphone outputs could be better utilizing the balanced internals, or the single ended internals more effectively.
-For instance- the Cavalli Liquid Carbon has a very good single ended output, BUT when running cans in the balanced output there was greater separation, and way more power. The balanced output (in my opinion and a lot here) was way better. This is probably because the Liquid Carbon was made to be a balanced amp, and the single ended is near an addition to it.
-Now, you could have an excellent/superb single ended amp that will smoke a good/great balanced amp. It all depends on the build of each, and not just that one is balanced or not.
I know of single ended amps that SMOKE balanced amps and vice versa.
-Since some cans are easier to drive then others, cans like Grado, Focal Clear, Utopia, Elear, ect ect don't need tons of power to get the driver to move back and forth effectively. SO if the amp excels equally in balanced output as much as single ended, I don't see the balanced output being that much of a difference.
My last and BIGGEST take away from all this- Always
get your headphones terminated with a balanced cable, and then just get an adaptor that is balanced female to male single ended.
That way regardless of what kind of amp you get in the future you will be able to connect balanced OR single ended and never need to buy separate cables for each. There will be people here that will disagree with me since they don't want to add anything more to the signal chain by adding the adaptor. I think its a small price to performance (Very negligible if the adaptor is made well) for the ease of serious convenience and money.
I hope this helps you and others. and please, feel free everyone if you don't agree with my opinion/understanding on the matter.
ALSO
Who has a clear top for their 400i? I am curious people's opinion on wether they like the look or not. I think it looks DOPE with the clear top personally
