- Jul 7, 2014
Having a very difficult time taking the Clear off my head (plugged into the 400i). I want to listen to the Aeons on here but I don't have the willpower right now!!!
Very yes, I also experienced this and thought it was just me. I just leave my volume on full tilt because other applications sound seems blocked.Hey guys got my CMA400i last week and have been having problems getting the unit to operate in exclusive mode, i.e windows volume control still works. I have both exclusive options checked, have disabled all enhancements, and still nothing i have a peachtree nova150 set up the same way and have never had these problems as it operates in exclusive mode no matter the app. Anyone else having this issue or is just me.
LOL me too! I forgot about that incident. It does look nice, but then why not recess the 2.5mm?!Why is the 6.35mm output recessed? I literally had to use pliers to get a 3.5mm/6.35mm adapter out after the headphones popped out when I removed them.
YVWM47 said:Hey guys got my CMA400i last week and have been having problems getting the unit to operate in exclusive mode, i.e windows volume control still works. I have both exclusive options checked, have disabled all enhancements, and still nothing i have a peachtree nova150 set up the same way and have never had these problems as it operates in exclusive mode no matter the app. Anyone else having this issue or is just me.
Sounds like a good thing to make Questyle aware of. They seem to be decent at releasing firmware and drivers for their products and I imagine that issue could be fixed with one.spookanide said:Very yes, I also experienced this and thought it was just me. I just leave my volume on full tilt because other applications sound seems blocked.
Anybody tried the CMA400i with a LCD-X?
@TSAVAlan, about volume indicator, is it lighted? on my unit I can only spot light passing thru those tiny holes, initially I thought it was something like lighted optical fibre. I wonder if something about the volume indicator is not working on my unitQuestyle does listen, the CMA400i finally has an indicator on the volume knob! Probably one of the most common things I heard feedback wise was that it was tough to know where the volume was on the older units. The little gain switches on the bottom are a little hold over from the CMA800P where we had to take the top off the unit to adjust the gain.
Questyle does things a bit differently but least they help out with gradual changes over time.
