New Pro Balanced Amp!!
Mar 22, 2010 at 8:55 AM Post #16 of 74
Originally Posted by fradoca /img/forum/go_quote.gif
this is a reference monitoring system not just an amp.
This piece of gear has been made for the pro audio world.
The signal must be the most neutral and transparent possible
with no coloration at all.The fact that the inside shows
few things means that the audio signal has to be the purest possible.
After all this has been build for mastering and QC purpose.
Not really, less components visible means simpler design using monolithic opamps, nothing more.
Mar 22, 2010 at 9:08 AM Post #17 of 74
Originally Posted by Lil' Knight /img/forum/go_quote.gif
Looks nice from the outside. Not sure about the internal though. Don't know why they need a huge case for this.
Looks cheap for a 790$ amp but maybe its because i'm used to the audio-gd crowed internal, the Slee Solo also don't have many items in the internal and have good reviews.
Mar 22, 2010 at 2:19 PM Post #18 of 74
By that sort of logic, the little CMOY collecting dust on my shelf is better still. Especially since it uses a pair of 9V batteries, keeping any dirty AC power from possibly colouring the signal.
Mar 22, 2010 at 5:51 PM Post #19 of 74
Yeah but it doesn't look anything like that.
Mar 22, 2010 at 6:26 PM Post #22 of 74
Originally Posted by jp_zer0 /img/forum/go_quote.gif
it's only for low-impedance phones that's for sure. Look at those mickey mouse caps and transformer.
No, it's a costant current drive, high-impedance output, couples only with high-impedance headphones.
Mar 22, 2010 at 6:28 PM Post #24 of 74
That really doesn't make sense, transformer doesn't look small and having large PSU caps doesn't mean anything in terms of high vs low impedance driving ability.
Very cute on the "Micky mouse caps" thing though!
Personally, I was more shocked at the home-etched PCB without any solder mask.
Mar 22, 2010 at 7:07 PM Post #27 of 74
waaat, I won't pretend to know anything about electrical circuits so I'm not arguing with you but damn. How can this possibly work?
Mar 22, 2010 at 7:19 PM Post #28 of 74
The design of an amp has more of a bearing on high vs low impedance driving ability than the size of caps and transformer (to a point, at least).
Mar 22, 2010 at 7:28 PM Post #29 of 74
what do we need caps for then?
(I know they only hold energy, don't make any...)
Mar 22, 2010 at 8:08 PM Post #30 of 74
I can't make out the area very well, but if those first 4 IC's are rectifiers, the caps are likely just for dc smoothing before reaching the regulation circuits. But then I'd expect to see at least a little metal on top of the regulators. Dunno.
