Jamey Warren
Member of the Trade: HeadRoom
- Sep 23, 2003
No. We do not use different gain settings. There is a very wide range of settings with the three gain options and the higher output of balanced sources is already considered since there is the option for a balanced DAC. Our balanced amps are designed to work well with both single ended and balanced headphones and I feel there is plenty of adjustment room. If you purchase one of our amplifiers and have issues with the useable range it would be relatively easy for us to remedy that. Personally, I don't really think it would be an issue.
Originally Posted by Luco When you guys are determining the gain settings for amps with stepped attenuators, do you give different settings to the balanced amps to allow for the fact that balanced sources are on average much louder than unbalanced ones? |
