New Innards For HeadRoom Amps
May 12, 2006 at 11:52 PM Post #153 of 202
Originally Posted by Tyll Hertsens
Pretty sad, us not having these pieces of information clear.
So, what's the answer? And some internal amporn shots of your home and max lines, as well as the DPS wouldn't be a bad idea while you're at it...
May 14, 2006 at 9:03 PM Post #154 of 202
No-one wants to answer my question? How can I possibly be a good fanboy if I don't know how many PSU's there are in a Max Balanced?
May 15, 2006 at 3:22 AM Post #155 of 202
I'll work on it. I'm kinda sick right now, but I'll get Andrew on the pix and we'll see if we can't get some up befor we leave for the Stereophile show.
May 15, 2006 at 3:33 AM Post #156 of 202
Thanks Tyll! I need something to do - I got my middle finger caught in between two rather large, heavy sash windows while doing some DIY Air Con installation, so it's rather bruised. When am I going to learn to stop saving money and start looking after my hands (which is of course saving money)?
I'm sick too. Get better soon.
May 15, 2006 at 4:52 AM Post #157 of 202
As Tyll said, we'll work on getting those pics up soon. To answer the question regarding power supplies, I'll do my best. In both the Home and the Max, there are technically four power supply rails which are derived from two input transformers. Each transformer output is regulated into + and - 15VDC rails which gives an individual +/- 15V supply for each pair of modules that powers either the left or right side of the headphone. Amporn coming soon.
May 15, 2006 at 5:58 AM Post #158 of 202
Thanks Jamey! Why did you go from 4 to 2 transformers in your top of the line? Is there no real/potential benefit from the extra transformers?
Btw, I'm impressed by your new sig.
May 15, 2006 at 2:43 PM Post #159 of 202
For some people, four transformers is quite a bit of overkill. We choose larger transformers for the the new line and kept it to only two. When designing the Max Balanced and considering the power supplies, we couldn't hear any degredation of sound compared to the BlockHead. We had something similar to the convertable for listening tests.
May 15, 2006 at 3:18 PM Post #161 of 202
I don't have a pic but, it's just like a Max Balanced circuit board with only one pair of balanced headphone jacks and some sockets for the modules. I'm hoping that someday that prototype will end up as my balanced amp for home use. Maybe I'll post some pics after I get her all dressed up.
May 16, 2006 at 12:33 AM Post #163 of 202
Originally Posted by Luco
When you guys are determining the gain settings for amps with stepped attenuators, do you give different settings to the balanced amps to allow for the fact that balanced sources are on average much louder than unbalanced ones?
No. Because they are designed to run in single ended mode, and if the gain was halved, they might not be able to drive all single ended headphones.
Though, I can't be sure/remeber whether the gain wasn't slightly lower, but if it was, it wasn't by a significant margin.
May 16, 2006 at 12:47 AM Post #165 of 202
Well, I wouldn't really care if my balanced amp had problems finding the right volume for some unbalanced phones. I want it (heck, need it!) to be able to calibrate balanced phones to the right level. I would like an official Headroom reply to this.
Ok, Jamey will sort it, but I'm right.
I did own a Balanced Home.
