i20bot
- Nov 13, 2013
I'm selling mine if anyone is interested. PM for more info.
![](https://www.head-fi.org/attachments/1579657/)
I just gone to buy now the polaris take the mellow or the agrassive? i saw the difference in graphs but i still dont know what is better
do the mellow. highs are more intact, less roll-off as you can see from the graph. you can always adjust the amp settings to blunt really harsh highs on bad recs.
I went with Agressive and still use low bandwidth with my beyer dt 770 pro so I can really drive that bass without harsh trebles. I'd say it depends on what headphones you're using and whether you are treble sensitive.
Im use the hd 650.
with those you could go with mellow or aggressive. So it just comes down to your preference.
-Do you want the highs/trebles to be slightly toned down? Aggressive
-Do you want the highs/trebles to be mostly unchanged? Mellow
Remember the Amp also has Bandwidth jumpers to further tune the sound to your liking.
I'm sensitive to harsh sound but with the hd 650 the sound more dark then treble but in some songs it can be treble to much.
It's really confusing what to take...
If you find even the HD650 can give too much treble I personally would go for the aggressive version. Why don't you contact Jeremy and ask his advice? If you are not happy I would think he could change the version for you anyway.
I spoke with Jeremy and he told me that he uses aggressive and he told me just the aggressive adds more roll off for bright sounding headphones like you said.
ok guys thanks for the help i probably go with the aggressive one, i just need a recommendation to the good rca cable that connects to polaris from the stx.![]()
