jamor
- Nov 28, 2013
Contrary to the implications of what vapman said, you can't say a dac is "trash" just because of the chip it uses. If you are happy with the sound from the Yamaha, you should try to use it first if you don't want to spend money for an outboard dac. As to his advice re getting a signal to the polaris, i don't know what the hell he is talking about. I still think you can make it work by using the md/cd-r out jacks with rca cables to the polaris' in jacks.
While I believe you will probably get better sound (especially with headphones) from spending some extra $ on a dedicated dac, you can always do that later if necessary.
@jamor - Try the out (rec) of your receiver > connect to polaris input
Subwooper output may be mono.
I just purchased some RCA cables and I'll try those suggestions out. I don't have a good feeling it's going to work though because the model up from the Yamaha I have specifically has a documentation for pre-out connections and connecting external amplifiers while my model doesn't. If not, I could just get an O2 Dac or a Modi 2 uber? Unless there's something better in that price range. I'm still waiting for the Polaris to ship though.
