miwashi
- Apr 8, 2015
'm trying to decide between getting this or the SMSL idea. Which one is better?
3. 3.5mm line out.
Tuning is a reference to existing product FiiO Q1Ⅱ, because the output power is bigger than Q1Ⅱ, so I feel better.Gorgeous, how is the prototype measuring up @demond? You like what you hear yet?
What's your thoughts on the AK Dac implementation on this new baby?
P.s The spec's look pretty good, I believe they used one in the SDAC over at MD?
https://www.akm.com/akm/en/aboutus/news/20150522AK4452AK4454AK4456AK4458_001/
variable output,Is it fixed voltage or variable output?
I think there will be a chance for you to compare and prepare thie, It is expected to be ready for a tour audition next month..'m trying to decide between getting this or the SMSL idea. Which one is better?
I'm assuming this is referring to the line output on the rear of the unit.variable output,
Can adjust the volume.
E30 is the ADC volume design, not the analog volume,I'm assuming this is referring to the line output on the rear of the unit.
If so, this is probably a deal-breaker for me. I really wish the E30 at least had a switch to give the user the option to have the line-out be either fixed or variable.
Also, it looks like it's going to be a real tight fit between the USB-C cable and the coax cable.
We decided to modify the model E30.But why not E20 ? and still AK4452! atleast AK4490 should be there. Q1 mk2 is still weak and till now no proper desktop grade product from Fiio.
