BzzzzzT
I do have a decibel meter. It's a good point to make, but is not applicable to this situation. It is at both low and high volume. I also know others who have the same issue. I have had two Arcam DACs in the past and an RME ADI-2. I also have two other DACs in my studio; a Focuswright and Steinberg A/D converter and both have DACs for playback. I know the Focuswright has an AKM in it.Do you have a decibel meter? The Iris / Pontus combo (i2s) is incredibly resolving, with very little noise or distortion. It can be hard to judge volume just by listening if your previous system wasn’t as resolving. Ringing in the ears is usually a sign of listening too loud. I found this happened to me when I upgraded everything recently. By using a decibel meter I was able to find a safe listening level (and determine I was listening at unsafe levels for extended periods, but initially to my ears it did not sound louder than my previous DAC /Amp)
The Iris brought the problem to the chain. My Pontus 2 had no issues with this and performs better than all my other DACs with i2s until the Iris was introduced. The Douk audio i2s fixed it. It also sounds better timbre wise with the same quality of the Iris and slightly better dynamics. I am also running a low noise power wart from ifi with it. This suggests that the Iris is developing some harmonic distortion. I also get this with different sample rates. It's worse with higher ones, but this is also because they often develop harmonics above the Nyquist rate due to the added frequency information. I will have to try putting my old somewhat functional oscilloscope on the signal to check. It brought horrible pain to my ears and tinnitus which I have never had issues with. I decided to warn others after I noticed other posts with the same problem and people selling their setup because of it. I also have the problem when I run correction software to give a flat frequency response like Sonarworks. There seems to be nothing wrong with the Iris function wise. It seems to be a problem in how it was implemented.
I was wondering if anyone had the issue. It makes volume much more fatiguing and sensitive in a way no other equipment I have used in the past has done. I really love Denafrips and their DACs but the Iris was not a good purchase for me.
