New Cavalli Audio Portable Amp officially in the works
- Thread starter SoundFreaq
dexterash
- Feb 1, 2014
So it does have a DAC or not? Or it's just a "simple" AMP? Or it's not just "simple"? Or...what it is?
- Apr 5, 2014
its not announced.
- Apr 5, 2014
early reports from the keyboard of cavalli indicates that this will be a dac/amp with single end.
dexterash
- Feb 1, 2014
Single end as in no option for balanced output? But it it's a DAC also... no balanced output?
- Apr 5, 2014
that was the word almost 6 months ago (in that time a lot of things could have changed). They said there is not enough room for balance outputs (the dac/amp is still balanced but its terminated in single end) and the dac.
mulder01
- Jan 13, 2012
Wait, did I read that right? You mean to tell me they made a balanced amp but didn't put a balanced connector on the end because it's too big??
groovyd
- Jun 29, 2012
the connector doesn't change the sound in any meaningful way.
- Oct 10, 2002
Hi. First, yes the delay is ridiculous at this point. I expected more from this engineering team.
A good question about the output.
The DAC produces a balanced output. The first version of this portable has two discrete SE amps in it. These take up quite a lot of room. Hence, we only use a SE signal from the DAC to the amps. The other output of the DAC (the negative out) is inverted through a buffer to provide a line out directly from the DAC.
I want to say more, but as someone pointed out many posts ago, the announcement of this amp was premature and was based on project scheduling from the engineering team that was pretty far off. But, we are still working on it.
- Feb 5, 2005
Disagree. The development time is perfectly normal. The mistake is to make the announcement this early.
I always tell manufacturers not to post on the internet until it is imminent because you get expectation like this (nothing personal, though the example is convenient)
- Apr 5, 2014
A good question about the output. Of the many really dumb things I've done over the years, this isn't one of them.
Hello first thanks for the update. While the wait is bad the silence is worst (no idea whether the product has been scraped or no)
Second, In regards to the balance output from the dac, do all dacs output balance signal or just the one you are using?
- Oct 10, 2002
Thanks. In my case, the long time is abnormal. It doesn't take me this long to bring amps to production, not even half this long. It's simply use of an external team for key aspects of this amp that has extended the the time. Will only do this once.
- Oct 10, 2002
You know, I really don't know if every chip dac does this, but it seems an easy thing to do once you go through the trouble of putting the rest of it on the chip.
No, hasn't been scrapped by any means.
dexterash
- Feb 1, 2014
Any update?
As per my understanding is a DAC that mixes "old-style" AMP with new/actual technology? Or is it something else?
- Oct 10, 2002
The original idea was a DAC/amp combo like many other portables, but with my own amp design. After finally getting the proto I've decided to mod the design concept. And since I am no longer using external resources in the manner they were used for the first version, I will make progress faster. And when I say I will have something I will have it, even if just a proto for getting feedback.
