mandrake50
- Aug 13, 2007
Unless there is something wrong with your electronics becoming nonlinear with volume control position, this can only be an opinion.
We, as humans, often make an observation in a particular situation and then incorrectly extrapolate it to all situations.
If you want your volume control lower, boost the input level. Just with different recording levels of various songs I have needed to change the volume knob position 30 to 50 degrees to maintain equal sound levels.
As long as I don't experience channel imbalance, or noise, I have not heard any audible differences in my sound regardless of where the volume knob is set. In fact in some situations I have chosen low gain (because I do believe that changing gain can influence SQ) and run the volume maxed out. As long as I am getting the level I want, all is good.
I never owned an SL, so I can't make any kind of comparison. I have used different DACs with the CV2+ and it does make a difference in the sound. Right now I am using the DAC out to drive a Gustard H20 (which might be considered a more powerful amp, depending on how the specs are presented and read) and liking the results. But I doubt that I would be able to identify which amp was being used in a volume matched blind test.
I also quite enjoy the CV2+ just using it alone. Of course, if you find the SL adequate and like it as much or better, it makes sense to get rid of the CV2+.
