Hello,
I'd like to chime in with some quick initial impressions. Just received my Conductor 3 about 5 days ago.
Setup: Sennheiser HD 650's (stock), sourced by a Windows 10 desktop PC running Foobar with FLAC rip files
* Pros:
As a previous owner of the original HA-160D, as well as a CV2+, I can honestly say the C3R is a significant improvement over both.
I wasn't expecting to be that impressed, in fact I was just hoping it would be incrementally better than the somewhat thin sounding CV2+.
Well, I was wrong. The C3R blows the doors off its predecessors. It has a tremendous sense of clarity that's backed by what I can only describe as limitless power.
It's like the HA-160D, only exponentially better. In terms of clarity, it really shines when listening to a Mobile Fidelity CD rip - fresh details emerge all over the place, but it also sounds coherent and natural at the same time. In terms of power, the power is crazy. Recordings with a wide dynamic range can literally take your head off. You can go from a quiet passage to startlingly loud instantly - like a lightening strike. It takes some getting used to. Bottom end is solid with plenty of slam. To sum it up, the C3R is an impressive piece of gear.
* Cons
For some strange reason Burson decided to cut corners with the volume control. Yes, it has a fancy OLED screen with a PGA2310 digital processor.
And, yes, it has a fancy CNC precision knurled knob. Unfortunately, the one part that really matters - the rotary encoder behind the knob, is a piece of junk.
I've found that when advancing the knob click by click, it will sometimes stutter - and even go backwards (20, 21, 22, 23, 23, 22, 24, 25...).
The knob itself probably costs 20 dollars, while the encoder, with its wobbly plastic shaft, probably costs 29 cents.
Because of this, I've resorted to using the mini remote to control the volume.
Quick sidebar - there is no noise floor at all, at least on my unit. I can pause play and turn the volume up to 99 - and it's dead quiet.
