Hi Guys,
As you know, we have implemented design improvements to the Burson Play. When compared to the previous production version, the new one (1.1) is better able to work with sensitive headphones and IEM. Furthermore, 1.1 is less dependent on the quality of the power supply hence making it an even better product when working with PC internal power supplies.
If you don't use the Play within those parameters then 1.1 makes little or no difference to your listening experience. However, we are also offering customers an opportunity to update their unit to 1.1.
It's 99USD inclusive of postage and there is a little bit of DIYing involved. The process is simple and the instructions are as below.
* Order the motherboard from us for just 99USD inclusive of postage. (send email to:
info@bursonaudio.com)
* Use the hex key in the accessories box to remove the front plate, back plate and the USB receiver.
* Unscrew the 12 screws shown in the picture below. Please note that 2 of them are plastic screws and need to go back to the same places when implementing the new board.
* Screw in the new board. Put the USB receiver, front and back plates back in and ensure that all pin connectors are connected properly.
Done. but if you run into issues then we are always ready to help. : )
Furthermore, this process will not void its 5 years warranty.
Team Burson
