Dolores Dolomites
It is on paper, you're right. But you won't notice the difference unless you're playing 24/96 files, and even then I'm sure you wouldn't tell the difference since the H95 are good-sounding 'phones but not as discerning as to let you hear the gain. =)and have LDAC which is theoretically better than aptx HD
aptX HD sounds just as fine as LDAC with a 99% 24/48 max. FLAC files library like mine.
As for the Ferrari / Merc analogy (I'm a huge F1 "tifoso" by the way... This kinda hurts)... The only thing that doesn't fit is that if you're blasting at 300km/h (or even 250km/h for that matter) on just about any road, you're running the risk of killing other people along with yourself.
If you want to get permanent hearing damage by cranking your cans up to a dangerous degree, the only inconvenience other people will experience is that they'll have to shout at you instead of whispering.
Only reason why you won't get that is because you're listening to very quiet classical music, and even then the H95 have an adequate output, not to mention you can still gather a handful of dBs by digitally pre-amping the signal, although it's far from ideal.
Keep the volume at a reasonable level, gentlemen. Please. You'll thank me later. =)
Unless you're willing to die young on a steaming Ferrari while listening to _very_ loud music, that is.
