I had my H95 for 2 days now and here are my early impressions:
Nice fit and finish, I would say the build is comparable to the APM. Both are superior to my Arya (which is not a high bar to cross lol).
The pads of the H95 are a little small for my liking as they lack a little depth but surprisingly they are still fairly comfortable.
The headband of the APM is way superior to that of the H95, at least for my head.
The ANC of the H95 is mediocre when compared to the APM, it manages to block lower frequencies to an somewhat similar extent then the APM but the APM is much better in blocking the higher spectrum of the frequency range. So overall ANC is 50-60% as effective as with the APM I would say. In my testing, the APP2 also surpasses the H95 in ANC capabilities by a big margin.
The transparency mode is ok but creates a lot of background noise when used in its higher settings. I tend to us it at its lowest or medium setting for this reason. APM/APP2 is also way superior here.
When using the H95 for conference calls transparency mode becomes "Own Voice", which tries to amplify the own voice while speaking. This feature creates a loud buzzing sound for me when cranked up all the way. For me it is only usable in its lowest setting.
ANC can be enabled during calls though, like with APM/APP2.
Apple Music in Lossless Mode was used for all platforms.
I first tried the H95 with
AAC directly coupled to an
MacBook Air M1 and an
iPhone 13 Pro Max:
My first impressions here where they sound definitely better then APM when used under the same conditions, meaning with an Apple Device and AAC Codec.
But not as much as I initially hoped for.
The sound signature changes quite a bit here when switching between ANC/Transparency to Neutral, with Neutral having considerably less bass impact and amount.
The volume control doesn't seem to work very well either, as it can't be adjusted as precisely as the APM could be (less volume steps). This seems to be an OS limitation in combination with 3rd party BT headphones, as I have encountered the same issue using other Brands.
The sound itself is a little more detailed than the APM and there is definitely more impact in the bass region + it extends deeper into the frequency region.
Would I recommend the H95 purly for using it via AAC (directly connected to Apple Devices)? No, definitely not. The SQ improvement is too little with all of its drawbacks (worse ANC, worse transparency, bad volume Control granularity, Background noises under certain settings).
But then I coupled it to my old Pixel 2 XL running an Android 13 Custom Rom, the codec used is
aptX HD:
Paring was seamless with Google Fast Pair, almost as seamless as paring APM to an iOS device. Volume Controls is SO much better under Android. Not as granular as APM under iOS/macOS but almost.
The SQ is also much better now. Details are much more easily to pick up now without raising the volume level. The bass amount is slightly reduced but it's crisper and better defined in its texture. The sound also seems to suffer from less distortion, as the whole frequency range seems to be clearer.
Also, which I cannot really explain, the difference in Sound between ANC/Transparency and Neutral in Sound is almost not existent when using the H95 via aptX.
Would I recommend the H95 for using it via aptX HD/Adaptive HQ (via BT-W5 or directly)? YES, I would go so far to say that if you definitely will not use the H95 via aptX HD/aptX Adaptive the drawbacks compared to the APM/APP2 are definitely not worth it and both of them are a better product. But when used at its full potential, meaning via aptX HD or aptX Adaptive in its HQ mode, then the H95 really shine!
Edit: I found out, that the Adaptive ANC actually works. But it's very subtle. You can test it as follows: set ANC to Max and Adaptive ANC to off. You should notice a faint background hiss from the ANC. Now open YouTube and play a video on speakers with lots of chatter (for example a LTT video lol). While the video is playing, enable Adaptive ANC in the APP. The faint hiss should adjust and change its pitch as it is adapting to the noise made by the YT video, in my case the hiss decreased noticeably.
Range of the H95 using aptX HD is really good, as good as APM via AAC which is surprising as AAC uses much less data.
