FredA
- Dec 15, 2013
Good evening all. Last week I managed to sell my master 7 (old version, not singularity) which I was using with audio-gd di-2014 (via) through i2s. I sold it because my idea was to replace it either with r2r 7 or master 7 singularity (or even better he7s).
Today I had the chance to test denafrips terminator and, notwithstanding the wonderful presentation of the stage, the perfect separation of all instruments and the wonderful voices (even if a little bit far away to my tastes..on the back of the stage), all factors which seemed to be better than my old master 7, the resulting sound was too much "slow" and "bubbling" on low frequencies. As far as I'm reading around (even here someone posted that master 7 is better on this side) it seems that r2r resistance dacs tends to be slow and "audiophile friendly" on the bass frequencies.
If that is what I will hear when buying the r2r 7, I think I will prefer renouncing to the better identified stage, voices and resolution and chose the better bass of the master 7.
Additionally I noticed that files in 44.1 are sounding more analog on the master 7 (even with 8x oversampling) over denafrips Terminator (both in NOS or oversampled).
Anyway, I really appreciated the fact that Vinshine audio sent one denafrips terminator, to be tested and shared among a lot of Italians, for free. At least 10 persons already bought one after the test.
Mr. Qingwa should have to do the same to advertise his wonderful products.
Not sure the bass is better with the M7. It is less abundant with the r2r 7, that for sure. I think you can say that the bass of the r2r 7 is fast however. It's the only point for which there is a contest between the two dacs. Otherwise, the r2r 7 is a clear winner.
I had a lack of slam with the r2r 7 lately. I decided to upgrade some hook-up wire inside my amps (gauge 18 to gauge 16) and when i reinstalled the amps, it seems i might have had an inverted polarity on the right speaker for a while, seeing the way the speaker wires were bent. So i don't know if the problem was with the tiny hook-up wire or the partial polarity inversion, but things are fine now and as a bonus, the top end is now silky smooth whatever the recording i play. And i think the sound is a bit more laid back, not sure yet. But things are great really. I can only give the r2r 7 my very best recommendation.
