New Audio-gd R-7, R-7HE R-8, R-27, R-27HE, R-28 Flagship Resistor Ladder DACs and DAC/amps
Aug 4, 2018 at 2:36 PM Post #2,641 of 11,282
I would recommend the Master 9 with your R2R-7. (I have a Master 6, a previous model in this series.) The top-of-the-line products from Audio-gd have a reputation for value-for-money in the high end segment while the cheaper models have been getting more mixed reviews.
Aug 4, 2018 at 8:43 PM Post #2,643 of 11,282
I second this. The nfb-1amp is very good but you need the master-9 to extract the very last bits of info. That said, as a pre, the difference is very small between my 2014 master-1 and my 2017 nfb-1amp. You get better imaging mostly.
Plus the master-9 is a huge bargain given its costly architecture and performance. Never had a chance to audition it but it gets consistently raving feedbacks and reviews.
Plus using a quality acss cable, you will get a very transparent link with you dac. I have been using the same acss cable for the last 4 years and i think it is good enough that i will never have to upgrade it.
Aug 4, 2018 at 11:06 PM Post #2,644 of 11,282
Certainly the Master 9 seems like a great preamp, with 3 Rcore transformers! Sure it seems like a great pre-amp, but probably overkill for me. The NFB-1 fits my budget right now and the fully balanced feature may work well with other gear too like my SACD player. Not many fully balanced pre-amp at this price range!
Aug 5, 2018 at 10:06 AM Post #2,645 of 11,282
Well, comparing the Ref7.1 here with R2R7. The R2R7 is obviously a category above. So, I am not sure how the lower AGD tier fair, but the top of the line is certainly amazing
The da-7 boards produce significantly better highs. They are much faster devices and can produce more accurate timing IMO. In additon, the top end is smoother. This is not a small thing as the pcm1704k are very well regarded chips. All this is very obvious listening the very hard to reproduce sound of the accordion's top notes, which is so well done with the r2r 7. With the opamps swap in my pre, i have now more lower end extension and the sound i get has little to complain about. Some edginess with very old jazz records which i see as normal, but overall the balance is way better with the new accurate fw and a smaller number of records are hard to listen to. The sound of the accordion is really convincing, and i much appreciate the improved sense of depth with the new fw.
I am about to receive new loudspeakers, within a couple of weeks, directly from Australia. It is never the end of the journey for me.
Aug 5, 2018 at 10:09 AM Post #2,646 of 11,282
If i were you, i would wait and gather some money. I doubt you will ever regret buying a m9.
Aug 5, 2018 at 12:41 PM Post #2,647 of 11,282
The iFi may be slightly more colored which probably works better with a weaker source
Yes I came to the same conclusion. You can say the same about a tube buffer, a tube dampener, many wires, and also this W4S Recovery to some extent. Anything that behaves like a filter will have some collateral damage (ex: the atmospheric detail of the recording venue, or just the oerall dynamics)
I've owned & sold iFi's tube buffer, iUSB2, iUSB3, iGalvanic, iPower, Mercury, Genesis.
Aug 5, 2018 at 7:34 PM Post #2,648 of 11,282
Never bought a product that brought so little improvment if any as the ifi ac power. It's well made, solid, but i did nothing for my setup.
Aug 5, 2018 at 8:11 PM Post #2,650 of 11,282
Perhaps your setup is already very good. It only likely will beat a cheap Walmart DC adapter. I think mine did but I have not compared carefully.
Lent it to two friends. It did nothing for their setups either. Quite disappointing piece of equipement as far as i am concerned.
I made a mistake in my post, i was really referring to the ac power filter, not the dc swithing supply. Sorry for this.
Aug 5, 2018 at 8:15 PM Post #2,651 of 11,282
I am debating if I should get a Schiit tube headphone pre-amp lie this:
http://www.schiit.com/products/valhalla-2
Seems great value though probably still light years from Audi-gd’s hardcore R core transformer/balanced output.
Audio-gd is probably more transparent and neutral.
It is true tube buffer and reduce details though a good one usually effect is negligible. I tend to match tube preamp with my solid power amps. For a poor source like mine from MacBook, perhaps a tube headphone amp will work better for now. The audio-gd may be too transparent and “naked” for now? Besides I don’t even have a balanced headphone. so maybe I will wait a bit later for the Master 1 or 9 depending on if I still need headphone then.
Aug 5, 2018 at 8:22 PM Post #2,653 of 11,282
Perhaps. The audio-gd is not your typical solid state amp as it is a non feedback design, which makes it very smooth. But it won't remove so much harshness as some tube design would do.
Aug 5, 2018 at 8:28 PM Post #2,654 of 11,282
Non feedback gives a natural sound, which is one of the main raisons for which i enjoy audio-gd so much. Their amps are just never harsh by themselves and are reveiling nonetheless.
