Greetings dear community, Please help me with a problem. AES EBU input is not working for me in my DAC R7HE MK2. I discovered this recently, although I have owned the device for a long time.
When the port is activated, crackling and noise are heard, connecting a signal source does not help, no sound is played from the source.
I decided to check what could be the problem.
Opened the cover, and checked the signal circuits in the AES port.
As a result, I found out that in my DAC, pin 1 of the AES port is not connected anywhere.
Pin 2 is tracked to an empty resistor space on the board. Next, the signal should go to the transformer, but my DAC does not have a series resistor in this circuit.
And only Pin 3 is traced to the transformer.
I have a question. Do any of you have any information on the resistor value on your DAC board at the AES EBU input for Pin2? I indicated this place in the photo.
![photo_2023-04-10_03-54-10.jpg](https://www.head-fi.org/attachments/4418418/)
Do you also have Pin 1 not tracked and not connected to chassis ground?
Thanks in advance for your replies and help.
