Yes a DDCLOCK. The new new.I think AGD should come out with a DI30HE which has an internal high precision clock that rivals good external clocks that can also provides clock signal to the AGD dac.
Formfactor = R8HMK2
Has anyone tried Cayin iDAP-6 with R8HE / R7HE via I2s? Is it compatible both for PCM and DSD? Sound-wise this digital transport is praised quite highly and the price tag is reasonable.. I don't even think DI20HE is still needed in such a set up..I've been experimenting with different sources and the best USB signal I could get in my system was coming from a portable DAP (AK SE200) closely followed by Mac Mini (Roon). As much as I like the slightly euphonic sound of AK, the idea of constantly running a battery powered device is not gonna fly for multiple reasons. Is there any better option that wouldn't cost an arm and leg and will confidently outperform the two options above?
POWER POWER POWER POWER POWER....Just looking at the inside of all Kingwas designs brings emphasis to this, of how important it is. The power design in itself is as worth as the whole price itself, even more.Anything that can bring noise down matters. Recently, i got upgrades with these
1. Addibg a switch with linear power supply to replace the wifi connection to my streamer
2. Adding one gtx-d ncf (r) to my power strip and one to the wall.
3. Getting a better enclosure, high-quality wire and iec to assemble a new power strip
4. Applying grounding boxes and tubes on the power strip and isolator, dac, di and pre.
I think that the power is much polluted where i am with RFI. All these actions brought an improvemenr of the same magnitude as getting a higher class dac. Pretty amazing. Blacker background, more relaxed and laid back presentation, better staging (better depth and width), more details, juicier timbers and of course, more enjoyement. Power is the most important thing,.as Kingwa says.
Power cords too of course.POWER POWER POWER POWER POWER....Just looking at the inside of all Kingwas designs brings emphasis to this, of how important it is. The power design in itself is as worth as the whole price itself, even more.
A DAC, AMP has there potential, but only power optimization can bring the potential, if its polluted, yes cable improvements are all important.
My recent experience tells me it is: SOURCE, SOURCE, SOURCE (with clean power) and then all the rest. Especially in our case where we are spoiled by Kingwa's HE designs.. The AGD gear is amazing.. only if you feed it with high quality input.. otherwise it is: garbage in - garbage out.. I stopped using streaming services as well after a couple of tests where I played exactly the same file both in Qobuz and from a local SSD.. the difference is huge..A DAC, AMP has there potential, but only power optimization can bring the potential, if its polluted, yes cable improvements are all important.
I've been considering whether or not to upgrade to a wired connection and a switch.Anything that can bring noise down matters. Recently, i got upgrades with these
1. Adding a switch with linear power supply to replace the wifi connection to my streamer
Yeah Im configuring a new windows image with alot smaller footprint in NTLITE for a DIY streamer(ASRock J5040-ITX Mini ITX)My recent experience tells me it is: SOURCE, SOURCE, SOURCE (with clean power) and then all the rest. Especially in our case where we are spoiled by Kingwa's HE designs.. The AGD gear is amazing.. only if you feed it with high quality input.. otherwise it is: garbage in - garbage out.. I stopped using streaming services as well after a couple of tests where I played exactly the same file both in Qobuz and from a local SSD.. the difference is huge..
Used $200 Mac mini 2012 sounds WAY better than any Windows PC I have ever connected to the AGD rig (DDC or no DDC).. I will play with it for a while until I move along to the Aurender / Innuos territory..Yeah Im configuring a new windows image with alot smaller footprint in NTLITE for a DIY streamer(ASRock J5040-ITX Mini ITX)
Will buy 24pinatx connector and use iFi Elite or this time my first LPSU.
(Just test purpose and comparison between my other NAS)
The usbridge sig is way better than a mini. The Aurender should be even better.Used $200 Mac mini 2012 sounds WAY better than any Windows PC I have ever connected to the AGD rig (DDC or no DDC).. I will play with it for a while until I move along to the Aurender / Innuos territory..
My next step is a LPS for the mini (internal + external).. I could be closer to usbridge than you think )The usbridge sig is way better than a mini.
