FredA
- Dec 15, 2013
The nos mode were improved with v3. And it is pretty obvious. I find they are significantly better than before and not missing as much on dynamics. Very enjoyable sound.
ON the the older FW V2S I still prefer NOS2, something not right about NOS3. But anyway, maybe V3A or V3S would be different. I have my blaster ready but still need to download my Windows onto my MacBook to do the job, how annoying ! Is there a Mac version, I hope! Funny Kingwa himself uses a MacBook but has to run everything on Windows on his Mac including music playback. he probably runs Bootcamp.
Hi, I also have an R8 with V3A firmware and also prefer NOS3. Just seems to be more organic, more fully fleshed out, better front-to-back depth of soundstage, and better voice and instrumental separation. It looks like you are using the Gustard U16 as well. Can you tell me what firmware version and if you are converting to DSD?I have the R8 with V3A firmware and I also prefer NOS3 mode and have the "exact" same opinion about it. I couldnt express it better, it just sounds right.
On the other hand V2 boards and Accusilicons made a big difference, as also did the Gustard U16. Totally worthwile!!
Not sure about differences between v2s and v3s. My memory plays tricks on me.Making my way home to California and just checking in while waiting on the plane. I will be so happy to get home. My audio equipment has been turned off for 9 days and looking forward to relaxing mornings listening to music!
Has anyone returned their V1 DAC modules to Kingwa after swapping for V2s? I need to work on that next week.
I believe V2S and V3S NOS modes are identical?? Only V3A NOS was changed if my foggy brain cells remember correctly. Does TDA support NOS? Never attempted...
@FredA Congrats!! Probably best R7 (HE) on the planet. If anyone one hear deserves the finest it is you. Looking forward to a review...
I have R8 with V3A firmware, V2 boards, Accusilicons, Gustard U16, Wyred4sound USB Reclocker and Audioquest Jitterbug up in the chain.
I listen only PCM 16/44.1 from my Windows 10 streaming Tidal with Audinirvana+.
It sound "superb" and its getting better with time as V2 boards and Accusilicons are burning in, they just have about 100 hours.
I do not listen with headphones, only speakers.
I also have Audio-gd Master 1, connected with ACSS cables with the R8, Nord Acoustics NC500DM class D power amp, Q Acoustics Concept 500 speakers and a pair of Boston Acoustics M Subs, wich are very good for the price.
What is ironic is my r7 never sounded better as it is sounding now. I might as well just keep it.
Not sure. I suppose about 300 hours. Maybe less.Nice that you have the older R7 to compare. Give the V2 DAC modules some time. How long does Kingwa burn in DACs these days?
Very similar setup, although I currently only have the R8 as an Audio-GD product. I may purchase a Master-1 in the near future. I also do not listen through headphones. I have a Windows 10 machine streaming Tidal via Roon/HQPlayer and have been converting to DSD. I have music files as 16/44.1 all the way through DSD256. What firmware version are you using on your U16?
The r8 has a dedicated circuit to play dsd natively. So if the dsd contents are of great quality, it will sound really good.I use PS Audio 1.4 firmware. Ive tried PS Audio 1.6 firmware, but it reversed the channel, I dont know why.
Nevertheless, 1.4 sounds great.
If I understand correctly, you are streaming Tidal 44.1 PCM converting and upsampling it to DSD 256 with Roon on Windows 10. Am I correct?
If so, do you get better sound than just playing PCM directly to the R8? Are you sure?
As I understand, Ladder DACs are the best for PCM and not so good on DSD. Also if you upsample on a PC you could increase jitter as the computer has to work more to do it and that means more noise inside.
Ive read that the best and cleanest way to do it is to minimize the work done by the processor, not upsampling and minimizing internal signal processing as most HQ players do.
May be someone here, with more knowledge than me, could add some light on this issue.
The Audio-GD R2R DACs can surprisingly do DSD very nicely, and shines when the native DSD recordings are great. It is picky as if you have a poor quality DSD it will show as well. There was some issue with DSD256 noice but apparently that has been resolved by using the latest V2 board.I use PS Audio 1.4 firmware. Ive tried PS Audio 1.6 firmware, but it reversed the channel, I dont know why.
If you have a PC with powerful enough CPU it shouldn't matter if you upsample via HQplayer or do PCM--> DSD. I have tried that and there does not appear to be noise issue and seems to work great. That is not my usual way of playback since I have not paid HQplayer. But if your CPU is weak like an old duo core then yah, it won't sound that good as i did that in the past.
PS: Though I am no fan of HQplayer - there is something not that natural with it, may work better mainly when one tries to redeem some nasty recordings.
