You getting a balanced DAC as well? If not, why the NFB1AMP instead of the better C2?
why would the C2 be better? I was under the impression that the only difference is one is balanced and one is SE.
I would like for Kingwa to chime in and correct me if I misunderstood.
quote from website "
Different to the C-2 ( 11th Anniversary Edition ):
The C-2 is a single ended headamp and preamp (+/- 30V DC high voltage power supply ), The NFB-1AMP is balance headamp and preamp (+/-15V DC power supply ). So They had same output power specs can drive most headphone as well.
If customer like to keep your headphone with single ended connector (6.3MM), choice the C-2 get better performance than the NFB-1AMP.
If customer had the balance connector headphone or can modify the headphone with balance connector, choice the NFB-1AMP.
I guess the NFB1AMP is 2000MW @ 25ohm pure class A.
but he said if I want a warmer sound than my NFB28+DAC19 then I should get the C2.
I personally think its about right where it is now. I just want to keep the sound signature as close to the NFB28 amp. It will be close, but slightly better. And would be ready to attach a balanced DAC if I wanted. I could send the balanced output from the Geekwave XDF256 to the NFB1AMP. Just my thoughts anyhow. even though its 3.5mm TRRS to XLR.
Anyhow. the NFB1AMP seems to be a very good amp either way even it it's only 2/3 of the power output in pure class A.
