jdpark
- Jan 14, 2014
I'm not exactly sure why, as I'm not a computer engineer, and the computer engineers I've listened to generally don't seem to fully understand either... but there is quite a huge variation between sources when fed into the the DAC-19 (okay, really any dac).** Presently, I have an old Lenovo Thinkpad Edge with Windows 10 using Foobar2000, and a Jplay driver, which employs Kernal Streaming and some other stuff I don't understand, typically along with the program Fidelizer Pro, and, here's where it gets weird: I'm playing CDs and sending the raw PCM out through the USB cable that came with the DAC.
The sound is so far superior to any other set-up I've been able to achieve that it's ridiculous. The tone is dead accurate and at the same time not digital at all, free flowing and smooth, while the instruments are locked in place in very three-dimensional space and the PRaT is rock solid, no matter what I listen to. But the truly silly thing is that I essentially have a very cumbersome CD player. Granted, I would be happy to let any one in my area test this set-up out against a high-end CD player, which unfortunately I do not have on hand to compare with.
For some reason, I cannot seem to get files to play with the same rock solid grip from the internal or external hard drive as I can just playing CDs. And streaming in FLAC doesn't come close.
**For instance, when not fed a proper source the DAC-19 can still sound dark, buttery, and relatively musical, but it looses the sure-footedness and sharply defined imaging it is actually capable of. Indeed, with poor sources, just like with any other DAC, it can sound weak and fuzzy around the edges. But if you're planning on putting crap into your dac, you might as well stick with a regular computer sound card, which is in fact designed to play crap.
