Snake07
- Mar 30, 2010
Are there will be any more firmware updates?
There have been on-going development on both L5p and L3. They shares similar software structure so they usually get updated at the same time. Unfortunately there have been some out-of-work issues with the main software developer, so the firmware work was haul for some time. Now hes back to work and we should expect an update later this month.(hopefully?)
Great to heard that!! Do you know what enhancements will be included in the new firmware? Thanks!
I've never owned a DAP before so I was quite intrigued by the L3 when I first saw it, and the price is really good too. But with all the talk about the firmware being spotty, I'm reconsidering if I should go for it.
It really depends on what you are looking for. If you are looking a smart device that works similar to your cellphone, but sound better than a phone, L&P devices isn't what you are looking for.
But if you are looking for a portable device with great sound and minimal functionality, then you are good to click purchase button.
New firmware 1.0.1.2
-Added support of AAC/M4A
-Improved compatibility in USB-DAC mode
-fixed japan menu translate
-fixed some issues with micro sd cards
-fixed issue with default settings restore
Installing on fw v1.0.0.9 or higher
download:
http://pan.baidu.com/s/1dFdqi2l
I can't download it.
can someone re-upload?
thanks.
