Ajayrnb
- Nov 18, 2014
I am not sure about the terminology. But I guess yes, it is bass bleed with any/ normal mode except "Rock" mode.
Op: can you please add "Extra Bass" in the title?
Hi,
I am considering to return SONY MDR-XB950AP/H ($99) and get a Sennheiser Urbanite XL($ 250). If anyone tried both of these headphones, could you please suggest if it is worth buying the expensive Urbanite XL compared to XB 950?
Is there the relative quality improvement in sound?
Thanks,
Ajay
Thanks for the feedback AudioBreeder. I finally thought of taking BT version return AP version and I was waiting to get it from Sony (out of stack and they offered discount). But today all the prices are reset to original $199. For now thinking to keep AP version. Can you suggest good bass headphones with clear voices while watching movies (action) or at high volume music (I feed bass bleed with AP version).
And is there noticeable difference between AP and BT versions? If not now, I can take BT version for this christmas if they sound better with a considerable amount of quality. Please suggest.
Thanks Fuzziekiwi for your suggestions. I have checked both the suggested headphones price & amazon reviews (not many though) and finally decided to go with Sennheiser HD7DJ/ Sennheiser HD8DJ. I see you have HD7DJ (3rd place )and I wanted to check with you again before I buy these that I am a bass head and my primarily usage of headphones is for movies and then the 2nd priority is music/ games. So please reconfirm if Sennheiser HD7DJ/ Sennheiser HD8DJ fulfill my requirements (bass head & movies without bass bleed). Thanks.
Hi Fuzziekiwi,
I have got HD8DJ headphones.. as you said, these doesn't have the bass bleed and the bass is crisp as I always wanted. These are great sound wise but the comfort wise I feel Sony 950 AP are much softer and better.
I prefer sound than comfort,so I am keeping these headphones anyway, in addition, Is there any headphones that gives us theater experience (surround sound/ dts/ dolbyetc.. not sure about exact terms to call it) while watching movies? and just for my info.. does HD 650 has less bass compared to HD 8 DJ?
Thanks.
