music81
- May 13, 2015
Hello. I purchased this player after great reviews from this website. Well, I can't get enough bass with this player. I do not want to spend any more money just for this player. I have tried all sorts of EQ settings and nothing is working to gain more bass. Is there any alternative like ROCK BOX I can install for more bass? Alternative Parametric EQ? Their current Q setting needs to be more emphasized. Headphone's I am using are SONY MDR 7520 (5 - 80,000 Hz, 108 dB) & 7550 (3 - 28,000 Hz, 108 dB). In the computer, both headphones have lot of bass and do not need an AMP. So its the player giving headache.
Secondly, I put in 112 GB, 12,000 songs, 48 some folders worth of MP3's in my 128 GB Lexar SDXC card. The player only read 5000 some songs. How do I enable to read all of it? I have done the update memory and the max it reads is 5k. This is a big problem if it don't read more than 5k because I bought this so I can put all my music in there. Any way to fix this with firmware update?
Thirdly, any song that you play and pause or shut off, it will remember. But if you change the folder and play something else, it won't remember the earlier song you left off, so I have to listen to the whole folder again. Any way to save those songs like COWN player does in its database at least 20 songs you can go through that have been played in past and will continue from there.
So if you guys have any touch with FIIO people, please tell them to update a firmware and fix these issues fast because I am having hard time getting respond from them quickly. Its taking forever and no help at all. Before I toss this in a trash can or play catch with my dog, please help. Thank you.
