My Sennheiser HD-280 Pro headphones are great, but no matter what I do - they clamp my head too tight and I get headaches within 10-15 minutes of their use. I am very sensitive to head clamping - more sensitive than an average person. AFAIK there is no way to stretch them permanently. I kept them stretched for 3 months now, but they still clamp once I put them on my head. Is there a way to fix the clamping? Maybe I could heat up the middle of the part that bends with a heat-gun, and then stretch them out, so plastic solidifies in a new, relaxed position, and stays that way..? Otherwise I will be selling them somewhere at some point and looking for better ones. I would like similar or better sound quality - please see requirements below:
- Must be very gentle, soft, and easy on the head. There should be no clamping, with cups just touching my head with something real soft.
- Must produce relatively high quality sound for its price, equivalent to HD-280 Pro's or better.
- Must be rated @ at least 80ohms, but higher ohms are preferred due to one of my sound cards being rated @ 10ohms and another @ 20 (or 35) ohms. I want optimal 1:8+ ohm soundcard to headphone ratio.
- Can be either closed or opened - doesn't matter, but closed is preferred.
- Must be "monitoring" or simply be without enhanced bass or any other sound enhancement. I want to hear sound close to the way it was recorded.
- Must be $200 or less and available in USA, UNLESS there are no headphones for such a price that can offer that very gentle, soft, and easy on the head experience, in which case I would be happy if you listed more expensive headphones because gentle and soft experience is priority for me this time around.
Please help me out on this one. I am NOT an audiophile, but I must say HD-280 Pro's sounded better than any cheap headphones I used in the past and the difference was obvious. This time I want similar or better quality but with super-good comfort to spare myself of headaches.
Thank you!
Thank you!
