If you're in serious need of work, I'd recommend going to a temp agency, and accepting one of the temp-to-hire type positions. Do the usual work your butt off,show up everyday/on time, and other people will weed themselves out (you'd be surprised how many people in temp jobs see "showing up to work everyday" as not being a requirement). I actually ended up working in corporate management for a good length of time, starting out through a temporary agency (in your situation-fresh out of school).
I'd also recommend that you go to your local UPS or particularly Fed-Ex. People in both temp to hire and these transportation companies seem to have a high turnover rate, and as far as I know all their line managers/shift managers/Sort Managers must have degrees and started as loader/unloaders (FedEx). These type of companies are always looking for educated hard working people, so put your degree to some good use in those places..
I'd like to suggest not shooting too low in your job search especially if you are listing your degree on a resume or application, because you're likely to be seen as being overqualified for the position. Employers are looking for someone that's going to stick around for a while, and even if it's not necessarily the case, they are going to think that when the next best job opportunity rolls around you will be out of there.
I'd also recommend as others have said looking at other jobs that are not in your field. Start from the bottom and decide within a few months if you want to work there, what opportunities there are to move up, how stable the line of work is etc. You never know when one of the "higher ups" will leave the company. There are plenty of opportunities to move up just because you have your degree, and others don't. A degree says not that you know A,B, and C, but that you have the ability to learn. That's what I believe companies are looking for. I have used this to my advantage over the years, and in fields that have nothing to do with what I learned in school.
One thing I think colleges/universities do horribly is preparing new grads to enter the workforce. It's not like in the past where boom boom boom you get a degree, you have a good paying job for life. With the economy the way it is, you just kind of have to roll with what's out there and be as flexible as you can.
As a last thought, if you ever think about going to school down the road I'd highly recommend PTA school. I believe it's a 2 year degree still, the pay is decent, and hospitals/clinics are always looking for good PTAs.
I haven't been job looking for a while, but I know it's tough out there especially if you're getting started, I wish you the best of luck.
