Mar 30, 2019 at 10:50 AM Thread Starter Post #1 of 2
redking
France
Hi, I'm new to the ChiFi universe. I've just bought 2 IEM : KZ ZS3 and KZ ZSN Pro.
As I don't like the stock cable of the ZS3, I've decided to buy the **** 16 Core Silver Plated Cable that I found on a review of CCA C16 here.
But after researchs, I found that they are several "versions" of 2-pin connectors : A paragraph, B paragraph, number C...
I'm totally lost. Is all of these connector compatible ?
Where can I look the "version" of the connector on my IEM (I don't find it on the product page) ?
Regards
Apr 3, 2019 at 7:29 AM Post #2 of 2
According to the website of Allie express , KZ ZSN pro uses pin type with the measurements: 3.5 mm, 0.75 mm
Source: https://nl.aliexpress.com/item/KZ-ZSN-Pro-In-Ear-Oortelefoon-1BA-1DD-Hybride-technologie-HIFI-Bass-Metal-Hoofdtelefoon-Oordopjes-Sport/32994234148.html?spm=a2g0z.search0104.3.1.2897140cCoexzo&ws_ab_test=searchweb0_0,searchweb201602_9_10065_10068_10890_319_10546_317_10548_10696_10084_453_454_10083_10618_10304_10307_10820_537_536_10843_10059_10884_10887_321_322_10103,searchweb201603_70,ppcSwitch_0&algo_pvid=6b23cf34-d50f-4c1d-8bc2-928cede48bfd&algo_expid=6b23cf34-d50f-4c1d-8bc2-928cede48bfd-0
They do have several types. I guess the width of the IEM connector is 3.5 mm and the pins are 0.75 mm long.
KZ tells you for which types a certain cable is.... for non KZ cable it will be a guess, because the connector is not always exact the same in length, width and even form: square, or or square with a point on one side.... maybe ask different stores if it is compatible with your IEM(s).
Have a look at the website which cable and measurements the other have. Hope you find another good cable. KZ does make silver cables as well, next to their oxygen free ones.
