Need Help Setting Up a Multi-Amp/DAC Switching System for Headphone Testing
- Thread starter chrisyak
chrisyak
Member of the Trade: Headphone Flipper and Reviewer
$1000 switcher is pretty expensive. Convenance is not cheap but only 3 ins and outs but this Monitor is more aimed at mixing probably a cheap ADC /DAC would perform better and giver you measurements/ benchmarks if you want also for ABX testing. The monitor has the potential to color the sound incredibly.How I've been doing multiple dacs into multiple things. Sources are two dacs connected via usb and i select which on the computer. The out of the selected dac is routed into my 2400 audio imperium. It has 2 stereo xlr ins, 3 stereo xlr out, one multi that can be a third stereo in or a parallel out (subwoofers), an insert (stereo send and return for analog vu meters).
It has 8 buttons for level (app to program and different levels available for each out), relay controlled, passive and one of the quietest,most channel matched specs I've seen.
