mattlach
- Mar 9, 2009
Hi all,
I am the happy owner of a set of Beyerdynamic DT770 Pro's. (80Ohm version, in retrospect the 250Ohm probably would have been better, but you learn with time) I think they sound great, but lately I have had a little problem that bugs me.
I have been driving these out of the back of my computer, using the 300ohm max headphone output on my Creative Sound Blaster Titanium HD. I am liking the sound quality. It's better than anything else I have ever heard, but I don't know how the DAC and amp in it compare to what you guys on here use (probably not favorably). (In a separate topic, maybe I should replace the op-amps in it for better sound quality? This I know nothing about, just that they are replaceable.)
The biggest problem - IMHO - with this sound card is that it has a mechanical switch in the headphone out jack that automatically disables all other sound output, so if I want to use my stereo amplifier, I have to bend down under my desk, find and unplug the headphones from the back of the computer. Then when I want to listen through the headphones again I have to go through the same thing in reverse. It is very very very very annoying!
I was thinking maybe there is a headphone amp out there that can help me solve these problems, and get me some better sound out of my headphones at the same time. Since I already have an OK DAC in the sound card
What I would be looking for is something like this:
1.) Line Level Analog RCA out on back of sound card -> Headphone amp
2.) 1/4" or 1/8" jack on headphone amp to power headphones (capable of supporting up to 300Ohm if I ever decide to upgrade cans)
--AND--
3.) Line Level Analog RCA output from headphone amp to my stereo amp so don't have to keep reconnecting things.
Can you guys recommend something like this, or maybe another solution I can use?
I'm looking to spend no more than ~$250 or so.
I appreciate any suggestions.
--Matt
--AND--
--Matt
