bleudeciel16
- Mar 23, 2012
I'm considering buying the Schiit Bifrost. The USB addon is $100 extra.
So... the point of using an external DAC is to get it outside of the noisy pc case, right? So through the usb, you get un-touched un-altered pure sound. Right?
so, if you use spdif, that comes from either the motherboard's onboard audio or the soundcard, right? does that mean that the sound has been altered by either the onboard sound or the soundcard? which seems to me would render the dac useless if you're letting the soundcard or onboard audio molest the audio before it gets to the dac?
or maybe i just don't understand how this works?
my motherboard is the asus z77 sabertooth and it has optical spdif out on the back panel. would this be better than usb? (it would save me $100)
