wallijonn
Throwin' tantra.
- Oct 15, 2002
Kirosia,
This is what I am talking about:
The MSI K8T Neo2-F uses the same VIA K8T800 chipset.
http://www.msi.com.tw/program/produc...il.php?UID=608
Look at the that chart -
If you use DS mem and fill in all the slots your mem throttles down to DDR333.
It may not be a problem now - but if you upgrade to WXP64 or Longhorne you'll probably end up needing 2G of mem to work smoothly.
btw, that mobo is obsolete. The next grade up supports 1066MHz HT instead of 800MHz.
