AuroraProject
- Jun 13, 2004
If you're going to keep it in your room and want it on all the time and still be able to sleep I would recommend a case with 120mm fans. They are quieter and move more air than 80mm fans. I'm running a Lian Li PC-7077B for my main computer, it's got 2 120mm + 2 80mm case fans, and I've got a 92mm Panaflo on an XP-90 cooling the cpu. The Panaflo is running half speed and the computer is pretty quiet, quieter than the Dell I used to have which only had one fan!
