The E17K looks like it would be my best bet, although it only puts out 200 mW @32OHM which is actually less than the Andes at 220 mW @32OHM. This isn't a huge difference, but I believe I would benefit from a bit MORE than 220 mW as opposed to less, if there is such a device. If there isn't one similar with the 10 step, I could always order the E17K and return it if there is not enough power.
Do you think that the 10 step E17K at 200mW will provide cleaner/better bass? Or the bass boost switch on the A5 at 800 mW? I understand that the extra power does not necessarily mean better. What is the difference between how the 10 step works, and how the bass boost switch works that makes you think the 10 step will be that much better? Since I am used to the 10 step on the Andes, I agree that this will likely be the closest thing. I am just worried that 200mW is not enough power.
Regardless, thanks a ton for your suggestions and especially for letting me know about the E17! I would have been looking for that this whole time if I had known about it lol. If there is one with a bit more power, I think that is the closest chance I will have to getting what i'm looking for. I have learned SO MUCH from these threads and researching, this stuff is so much fun
