Hello, first post here!
I have just bought a v-moda boom pro mic and a pair of fidelio X2HR. When i plug it on my motherboard integrated audio, the cans sounds decent but the mic is absolute hot garbage, with very low volume and high static noise. On other pc, the mic sounds good. I really need to find a setup to improve my audio, both mic and sound. I use my desktop mostly for music listening and gaming. My budget would be less than 150 euros (165 USD) if possible. I do not need fancy gaming features, but i am fine if they are some.
I have done some research and found two possible solutions:
-An all in one unit, like the Schiit fulla 3, creative G6 or sennheiser GSX 1000. That would be my preffered solution as it is clean and simple, but i have no idea how good the v-moda boompro mic would sound on those. Apparently, the mic input is horribly bad on the creative units... I have seen mixed review on the fulla.
-Using a cheap usb adaptor for the mic only like this one (recommended by the modmic team), and a dac/amp like a fiio e10k. But what scares me here is having ground wiring issues...
Any suggestions?
Thanks a lot!
Any suggestions?
Thanks a lot!
