Hi
@dougms3. Sorry for the delay in responding. It had been a while since I checked this thread. Here is a link below:
https://www.aliexpress.com/item/1005001441359988.html
For the mods, I replaced the jacks and signal wire. The jacks were upgraded to CMC style 80micron thick silver plated jacks. And the run of signal wire inside the machine that ran between the jacks and the potentiometer were replaced with 24ga solid silver (no strands) air gapped inside of 20ga teflon tubing. I have a photo of the first upgrade I did which was replacing just the wiring and keeping the original jacks. Like I said I have replaced the jacks as of now and they have been that way for probably 9 months now. The jacks made a silly difference, improving bass performance quite well in purely subjective before and after tests. Obviously, none of my upgrades are amenable to blind listening tests, so I had to trust my ears on this one. I did use the same albums and tracks before and after upgrades, but given that the work took between 1-2 hours, there is no real clean psychoacoustic memory available. The wiring cleans up the signal and straightens out the tones. Again, totally my subjective experience. I can tell you that all of this "nonsense" was convincing enough to my ear to replace every single stranded wire and jack in every subwoofer, speaker, and electronic component that I own.
You'll note in the first picture that I have the original jacks in at this point. (The second picture shows the upgraded silver jacks.) I never bothered taking the circuit board out of the unit and instead ran silver wire to the top of the board, routing the wire to the side of the chassis so that it wasn't too close to the transformer. What I recommend you do prior to this "surgery" is to make yourself your own solid silver RCA cable using solid silver Eichmann bullets. Trust me, the solid silver Eichmanns sound so much better than silver plated RCAs and are simply worth the extra cost. This will allow you to hear the difference that solid air-gapped silver makes outside of the machine. If you like the results, then it is time to perform the surgery... If the cost for solid silver interconnects is too much, then you can build yourself solid air-gapped copper interconnects with solid copper Eichmann bullets. For solder I use 8% silver content solder, which works well with either the solid silver or the solid copper. When I solder I try to make sure that the metal-metal interface is surface to surface and then put solder over it to "lock it in".
But making DIY interconnects first is what convinced me to go crazy and potentially end the life of my Naim clone. If you don't hear a difference, then you're probably better off. I ended up spending probably 100 hours upgrading all of my equipment. It was fairly ridiculous and totally not scientific, but it sounded better to my ear enough that it made me do dumb things like rewiring the inside of my very prized hifi system and turntable. Made some near fatal mistakes along the way, but managed to come out on the other end with all my gear intact and sounding way better. Yay for crazy and unscientific.
