iamoneagain
I would have thought the way to use the Naim as a preamp would be to set your headphone amp at a set volume and just the the Naim to control the volume.Hello,
I recently reached out to Naim to have some specs i can’t find, it is Preamp output voltage.
Indeed at first i have been listening to Meze Elite directly from the Naim atom HE. This summer i had the chance to listen again to a great amp i i use to own, the Auris ha2 with Utopia and it was really nice.
Si i just got this amp back to my set-up, and yes the amplification is improved to my ears. There’s more transparency and impact.
But setting the volume at 100% with the Naim i got clipping with the headphone. The sweet spot is around 70% volume and the result is very good. Anyway, there’s a load the Tube amp can’t take, and i am interested to know how many volts come out from preamp…if someone has this information could you please share?
Meanwile they gave me an information about headphone power output i share here:
« The maximum single-ended power outputs are 89mW/600ohm (voltage limit), 1190mW/32ohm and 2225mW/8ohm (current limit) »
I’m pretty satisfied would the build in headphone amp but I wouldn’t doubt you could improve things more with a nice tube amp.
