qusp
Member of the Trade: Twisted Cables
- Jun 18, 2008
yes youre right, though implied, I missed one word there Steve, symmetrical, but well you know I was set on using the words that were used to say it wasnt balanced
in simplest terms
this^
hahaha, you are right, the odd person actually does say that down here, but around here only for comedy.
yep all 3 amps i'm using at the moment are lowZ, the lowest 12.5 mOhms and the highest ~30 mOhms. I think you would agree doubling that is of no consequence. I use multidriver IEMs a lot and they thrive on these amps
Ok, simply put, balanced means equal impedances with respect to a reference point which is typically, but not always, ground.
The voice coils in a loudspeaker or headphone driver are typically symmetrical which makes them inherently balanced. Same with the windings on an audio transformer for example. The reference is the center of the winding. It doesn't matter if there's not a physical center tap to force balance. If the windings are symmetrical, it's balanced. Period.
se
sounds like one of your weird se definitions
may as well say a resistor or an inductor is balanced.
Yep, thanks, Bob's yer uncle.
30 mOhms!
Good grief, man!
Ridiculously high!
Sell it!
No. That's what "balanced" has meant in terms of audio interfaces and signal transmission for over a century. It's what makes balanced interfaces work with regard to common-mode rejection which is its whole raison d'etre. Any imbalance in impedances leads to a reduction in common-mode rejection.
It's the so-called "high end" audio industry that's come up with its own "weird" definitions. Many don't understand just how balanced interfaces work, which is why you'll see such follies as "balanced" gear with two completely separate signal paths per channel from input to output.
se
It seems that you are confusing a symmetrical device with a balanced device and are stretching the definition.
An example of a balanced device may be a transformer with a centre tap on the secondary. Obviously you could use it to create a balanced signal from an SE signal.
It makes no difference to a headphone or a speaker whether it is driven balanced or SE as the headphone or loudspeaker will not reject common mode noise if it is driven with a balanced signal.
A loudspeaker is not a differential receiver.
A transformer may be symmetrical, but this will not make it reject CM noise.
Judging by your tone there is no further point to arguing with you so.......I. AM. OUT.
balanced audio is only referenced to ground/reference through the power supply (and not even always)....
are you referring to "ground" as being the negative signal or ground as ground to neutral?
I'm aware. some people just refer as the negative signal as ground. and since there is this ambiguous argument of what balances really is i thought i'd clarify.
Ground as in "Ground to Neutral".
In typical residential, the ground which is tied to earth.
Assuming your equipment is grounded, of course, i.e. the AC power cord has the third pin: the ground pin.
