Frihed89
Thanks again. Yes, I like the 6SN7GT as an output tube. That's what you mean by driver? Or did you mean input tube?
OK I will check, but help me find them, please....and thanks again. I peaked in today and wasn't sure what I was looking at.
I need to see if I can hear the difference between high and low power. I have never listened to the difference.
Originally Posted by Bolder /img/forum/go_quote.gif Actually you should be fairly safe with the 6BL7/6BX7 as output tubes. They draw 1.5 amps each. It you use a 6SN7 as a driver, you would be pulling roughly 3.6 amps. The 6AS7 draws 2.5 amps each. Using those tubes would possibly be a problem. I would suggest that you consider completely disconnecting the switch and running the amp just off the regulated 260 V. Dr. Gilmore's simulations show much poorer performance at the higher voltage. The HV doesn't benefit anything and that switch could still fail. See what diodes are in your unit. The diodes in Tyson's are only rated to 1,000 volts and 3 amps. Turn on surge from trying to fill the big caps peak at well above that rating. The same diodes are used in the filament circuit. I think you would want to use something at least double those ratings. |
