studeb
- Nov 5, 2003
the current underground fav for needle cleaning is the "Mr. Clean Miracle eraser" Just drop the needle onto the eraser a few times and you are done. People usually cut it up into small squares, poke it on a toothpick and go. Do not use them wet, and do not brush with the eraser either.
You can make a RCM out of an old vacumm cleaner and record changer. Search the web. If you want to buy something start with the disc doctor system with the brushes and clean manually.
