DervishD
- Mar 30, 2008
Hi, inabstracto
DervishD, do you think A151 complement Clip+ well? I also use this player and am currently looking for durable earphones that will go through hours of jogging without any scratches. Isolation and overall sound quality are also factors but it's the build quality that brought my attention to A151s.
That's exactly my current portable rig: the A151 and the Clip+. They fit quite well together, and in fact (although I'm risking being burnt alive for this) the weak link in the chain is the Clip+. I won't go into details but I'm very disappointed with this player.
The A151 are surviving quite well my commutes, no scratches, no damage, and I'm not particularly careful with them. I mean, I'm very careful with my belongins, but I don't put extra attention in the phones, they receive the same tender loving care as the rest of my possesions.
The A151 cable is surprising me a lot, it is resisting, without any kind of problem, the hard life in the mass transports in Madrid. People is not as careful as me with MY belongins and the cable has suffered a more than fair amount of pulling, stretching, etc. without any damage. I'm glad of the A151.
If you're going to use them running and isolation is important, try foamies instead of silicone tips. Isolation increases and sound is not affected negatively as long as the foams doesn't protude much from the nozzles. I'm going to write a small review of different foam tips. In fact, I should have written it a week ago, but I can't afford the time right now. So, the short version: I'm using cut-to-length SoundMAGIC foamies with a great deal of success.
