gorman
- Jan 22, 2004
Sure they do, but as far as I can guess, what's broken here is not the highs driver, is the contact that leads to it, the cable, the soldering... something that fixes itself when I apply the slightest pressure on the outside of the earpiece, toward the "point" pointing toward the top of my head.
Originally Posted by lindrone My guesses is that the driver failure has nothing to do with the movements inside the casing. At any case, the only part that moves dramatically during normal use is the sound tube section. You have to apply a lot of pressure to cause movement and failure for other drivers built inside the casing. Things break without reasons all the time. |
