chinsettawong
You should just go ahead and do it.
hello Wachara. I have tested it in a srx driver. no positive results. Once I had a dull sound, and secondly no sound at all.If you are looking for something challenging and possibly fun, try double diaphragms.
Hi wppk,hello Wachara. I have tested it in a srx driver. no positive results. Once I had a dull sound, and secondly no sound at all.
Hi Jab. If you are talking about the wire, I don't use the original wire, I used a lambda wire, then there is no central plug.Hi wppk,
when you modify the driver normal bias to pro, do you modify also the connector?
(removing the central plug)
i didn't change the bias voltage on lambdas. only on srx. and I only tried two diaphragms in an srx, just adding one in the driver body.Hi Wppk,
Frankly, I haven't investigated into Lamda series that much to make any comment. But it seems that the diaphragm is glued on the quite thick copper spacer rings. By changing its bias voltage from normal to pro, do you also somehow increase the spacer thickness?
About the double diaphragms, tell me more about how you do it.
Wachara C.
