thoppa
- Feb 7, 2007
Try the WAV 1411kbps - it won't take long. You should hear more precision in background treble detail, more dynamics, better stereo definition.
There are many types of caps and I couldn't begin to go into it here. If you want to know then read these pages :
http://waltjung.org/PDFs/Picking_Capacitors_1.pdf
http://waltjung.org/PDFs/Picking_Capacitors_2.pdf
High End Audio - Electrolytic capacitors
The last one is highly subjective so take it with a grain of salt !
I think you'll probably have to accept a short bit of cable for your adapter. I've never seen such plugs.
If your gear is used, you might want to check it isn't defective in some way. Can you listen to a new one in a shop ?
For me, I find it hard to eke out more performance from my hi-fi and most changes I make are more about tonal signature than outright performance. Getting a sound you like that isn't fatiguing is the best thing to aim for IMO. Spending US$500 does seem a little outrageous to me. However, I spent US$200 upgrading my DAC and I think it was money very well spent.
Tom
Originally Posted by Ntropic /img/forum/go_quote.gif I've tried A/Bing FLAC/320. I can't tell the difference. I can do 192 or below against 320, but even then, the difference is small. Only 128 is particularly worse compared to 320, but only in busy electronica. I do keep FLAC collections for lossless archival purposes, however. Burn in could be an issue. The previous owner didn't use the D2 much, so it's probably only had 60 hours or so on it. On the subject of caps, why use do amps use electrolytic caps? Why not those fancy aluminium caps you see in computer electronics? On an unrelated note, does anybody know of any 3.5mm plugs with barrel long enough to house a female 3.5mm end? I'm trying to make a straight impedance adapter (why, I don't know). On a slightly related note, the Pico, I believe, uses the same WM8740 and PCM2706 in the Boa, and with a different amp section. And other higher ($500 total) quality parts. Why do I have a feeling that the difference will be, again, small? |
Tom
