- Apr 11, 2015
Ah! Needs fo be a thick cable for that long. Regular Computer cable from Amazon @ 5m or even 3m crackles for me.
Back to my cup of tea.
I didn't buy mind for the sound quality rather for the connectivity. I expected reclocking was just more snake oil. But I was wrong. It does bring clarity and air. I don't have an external clock...yetI've just found this thread. I bought my MC-3+ USB around two years ago and it has never failed to give great service.
I use it being fed from a Sonore ultraRendu via a Mad Scientist Black Magic USB cable, taking its output to my Gustard X26 Pro DAC via a Canare DA-206 AES cable. It has an external AfterDark Giesemann King 10MHz reference clock, fed via a Belden 4694R cable. The Gustard, too, has another external clock, this one an AfterDark Giesemann Emperor Triple Crown.
The Mutec was modified by Coherent Systems to delete the internal SMPS and is now fed by an external 5V supercap LPSU. It was also internally enhanced with a selection of very high quality replacement caps. Coherent seem to be the only supplier able to modify the MC-3+ USB with Mutec's blessing.
The sum effect of precision reclocking and using two master clocks is extreme detail in a very dark soundstage, with the acoustic of the venue, note decay and space coming through very clearly. Timing is metronomic in precision and attack. The sound is very non-digital and non-fatiguing, just liquid detail from Qobuz hi-res streams.
Adding a Mutec 10m clock will blow you mind..
The problem with most of the Chinese clocks that are affordable (haha) is that they have only 50 ohm output and the Mutec uses the standard pro 75 ohm input.The Mutec is very pricy. What I might do is another of my 'trickle downs' by buying the top AfterDark clock for the Gustard, moving the Emperor Triple Crown down to the Mutec and using the King on the EtherREGEN.
Well, Mutec seems to prefer square wave clocks, the REF10 page https://www.mutec-net.com/product_ref_10.php says:I understand, but it doesn't really apply to sinewave clocks, especially over short distances.
See John Swenson's paper on the subject:
Considerations regarding usage of external reference clocks
No, it has WCLK out and some programmable clocks that seem to be based on multiples of input clocks, but cannot output 10 MHz.Hi.
Can the MC3+ USB be used as a 10Mhz master clock reference? If that is possible then would it possible be used as 10Mhz reference generator and at the same time as a USB interface?
Thanks
I read somewhere that Mutec is going to release a new version of its mc3+ USB reclocker. is this true? Does anyone know something?
