Musiland "Digital Times" 24/192 PCI card (digital output only)
Jun 1, 2010 at 12:57 AM Post #16 of 55
Response from one of eBay sellers:
>>Yes, it has high precision mode. I am not sure if
the RCA is 75 ohm or not and the manufacturer hasn't
announced any jitter measurements yet.
Jun 1, 2010 at 1:48 AM Post #17 of 55
well it doesn't have much point over the 01USD as far as I can see...and you can plug the 01USD directly onto your DAC using this kind of adapter: http://www.uauctionsource.com/picture/SKU004912_0.jpg
the 01USD is running in asynchronous mode, the cable shouldn't matter...and last time I checked, a good USB cable was cheaper than a good coax
plus the 01USD is using pulse transformers so using this adapter we shouldn't have to worry about interferences between the 01USD and the DAC.
Jun 1, 2010 at 1:48 AM Post #18 of 55
This card is similar to the Musiland card discussed here:
TEMPOTEC Fans Digital March
www.tempotec.com.cn/en/2-Product/23-Fans/DigitalMarch/index.htm
Jun 1, 2010 at 1:58 AM Post #19 of 55
oops, I've edited my post above....and last argument, the 01USD runs in its own faraday cage...we both know that a PC case is an EMI/RFI nightmare
Jun 1, 2010 at 3:43 AM Post #20 of 55
I'm not aware of any DAC that will display the sample rate to the 1 hz resolution. So other devices may or may not be precise at 44,100 hz. Low jitter and precision are not quite related. The variance from exact 44,000 hz is due to the precision of the crystal which is probably 100 ppm (parts per million).
Jun 1, 2010 at 3:58 AM Post #21 of 55
Jun 1, 2010 at 7:07 AM Post #22 of 55
What about reports that Musiland 01USD has an RCA output which is 90 Ohm instead of standard 75 Ohm? And what about complaints that the output voltage is only 0.2 V instead of standard 0.5-0.6 V?
One guy on a Russian forum tested this Musiland box and found it to be not bit-perfect...
Jun 1, 2010 at 7:10 AM Post #23 of 55
Jun 1, 2010 at 1:26 PM Post #24 of 55
Well, this adapter avoids using a coax cable...so no interferences and no cable attenuation.
do you have a link to that test please? did he also try the BNC output?
some companies claim to be selling 75Ω BNC>RCA cables: http://www.stsi.com/assets/images/products/bnr-103.jpg
but most ppl agree that a RCA connector cannot be made 75Ω in the first place...
Jun 1, 2010 at 1:33 PM Post #25 of 55
well, this is your blog, right? http://hifiduino.wordpress.com/2010/04/08/reading-sample-rate/
it'd be nice to see what the HiFace feeds to this DAC
I've got some 10ppm clocks for my current transport, but I was told in the DIY forum that it'd be pointless to swap them..
Sorry, I wanted to say that I've never seen a DAC show 1hz precision "besides the one I implemented" :-). That means that you may be getting deviations in other devices but you never know unless you measure it. most of the deviation in the sample rate can be attributed to the crystal in the musiland and some to the clock in the dac (20ppm) and some to roundoff error in using integer calculation. Deviation also depends on the production batch of the crystals since it is +/- ppm.
Since I don't have a hiface, I can't measure it
Jun 1, 2010 at 1:43 PM Post #26 of 55
so you're saying that the 44105 Hz we see might be a "worst case" scenario and that the Musiland might actually be outputting closer to 44.1 than that?
Jun 1, 2010 at 1:52 PM Post #28 of 55
Jun 1, 2010 at 1:55 PM Post #29 of 55
Don't quite remember my calculations but most is due to the Musiland. So maybe 1 hz is due to the other contributions. But we are splitting hairs at this point.
Here is measurement of (another) Musiland I2S lines: http://hifiduino.blogspot.com/2010/02/musiland-driver-1082-fast-vs-precision.html
And if your Musiland was built from another batch of the oscillators, it could be better than mine :-)
