I recently tried optical out from my Cambridge 851N streamer to Pegasus and it sounds quite good. Even more analog sounding!
Musician Audio Pegasus R2R DAC
Agree.I also use the optical code from my Mac mini(2012).It has an optical out.No noise and nice sound.I recently tried optical out from my Cambridge 851N streamer to Pegasus and it sounds quite good. Even more analog sounding!
I use the Audioquest Vodka optical code.What the code do you guys use?
Because I like optical so much I ordered the Wireworld Super Nova Toslink 1 metre.Agree.I also use the optical code from my Mac mini(2012).It has an optical out.No noise and nice sound.
MaxA
Optical sound on my mobo MSI Z390 MPG Carbon Gaming Pro with Ugreen cable in too poor comparing to PPA v.3 + Ifi Defender (+ ifi iPower) + Neotech 1020. Just ordered Pink Faun USB bridge
Why stack up the boxes when you have a proper rack?
Because later my new audio switcher beside serving for two DAC has 3 short XLR cable. It' s convenient to handle them at top level under table without remote controlWhy stack up the boxes when you have a proper rack?
For HQPlayer, how much bit should be set considering linearity of Pegasus is so so as per ASR test by Wolf? I guess it's between 16-20 bit.
I have not used HQPlayer with Roon. Are they any good? Is it all about upsampling? As my streaming can do the upsampling do I still need to explore HQPlayer?For HQPlayer, how much bit should be set considering linearity of Pegasus is so so as per ASR test by Wolf? I guess it's between 16-20 bit.
yes, very good to upsample to 1536khz by Pegasus R2R with NOS. I also use Daphile to stream to HQPlayer EmbeddedI have not used HQPlayer with Roon. Are they any good? Is it all about upsampling? As my streaming can do the upsampling do I still need to explore HQPlayer?
MaxA
Meet the problem with firmware upgrade (Win 10 Pro x64 21H1)
Put 32bit libusb0.dll ro the flash program folder, there is the error with 64bit driver
Instruction:
PEGASUS USB audio firmware upgrade:
Press NOS for 3~5 seconds, the 48K and 2x lights will be on; Then press NOS again, the DSD light will be on, and the USB light will flash.
Click "Update USB MCU.bat" to upgrade, when the following screenshot appears, it means that the firmware upgrade is successful, please press any key to exit and power cycle the DAC.
but got
DENAFRIPS Co Ltd - USB MCU Firmware Update Tool
Firmware Programmer v1.3.0
Error 010: no valid device is found.
Failed, please try again.
Any ideas? All light flashing well as described
Instruction:
but got
MaxA
Does anybody tried to tweak Pegasus with capacitors replacement like Elna Silmic, Nichikon KZ?
https://www.head-fi.org/threads/musician-audio-pegasus-r2r-dac.942618/post-16632977Meet the problem with firmware upgrade (Win 10 Pro x64 21H1)
Instruction:
but got
MaxA
I havn't HiRes Audio F-20 device, I have "Musician Pagasus DAC" with original drivers. Working properly. I have no libusb0.dll in amd64 folder, another one version attached. Driver check turned off
- New firmware - https://drive.google.com/file/d/11aiJOhYeayJtAbbIN7JOq2HlC68XfEOH/view?usp=sharing
- Old firware - https://drive.google.com/file/d/11gCVgpNoiMNySr0zE4E7r8OJ_evq-qy7/view?usp=sharing
- libusb0 - https://drive.google.com/file/d/11a1NuKun-XeznDQqLICMjPL8kIygsqYt/view?usp=sharing
May be you'll understand what's wrong. All executables are in new driver folder
It seems Pegasus uses XING Digital Audio Technical Team's OEM digital interface
