darcman
Well... I ordered the new USB board w/ Crystek clock. I couldn't resist and ordered the MK3 deluxe board too. I decided to just get the AK4400 ( $30) and wait for some reviews of the AK4499 which, according to Gary, won't be available until mid 2020. I'll probably first try the new USB with my current MK1 to hear the difference in SQ and then install the deluxe MK3 board. I'm getting excited because this is the first major change I've made to my system in several years.
That's exactly what I did. When I ordered the Crystek USB board, I don't believe the MK3 deluxe available at the time. You will have to upgrade your firmware to support the Crystek USB board. I couldn't believe the difference that the USB upgrade made. I think I only had the Crystek in my MK2 for about a week when the MK3 deluxe became available. I heard a couple of raving rants about the MK3 deluxe so I ordered it up right away. The Crystek made a huge difference. I didn't try the MK3 deluxe without the Crystek, but I would venture to say the 2 upgrades are greater than the sum of the 2 parts.
You are in for a real treat that's for sure.
Rajacat
Good move on the deluxe board. I also have an older mp d2 mk2, but after consideration, I just went and bought the new mk3 DELUXE unit. Fired it up with Miflex caps, and NOS tubes from my older unit and it's quite a few steps up from the older series DACs. According to other parties the board upgrade on the older models brings you to the same audio nirvana. I'm so intrigued by it I'm getting the mod upgrades for my older unit too so I have something to tinker with.
If you upgrade a MK1 or MK2 with the Crystek USB Board and the MK3 deluxe motherboard essentially you turn it into a new MK3 deluxe DAC. I actually prefer the front facia on the MK2. But I could certainly live with either, there is no bad choice.
I think there might be a smidge more room between the binding posts for caps on the MK3 deluxe board. I didn't bother to measure as I was really in a rush to fire it up.
If anybody is wondering the value of the fuse on the MK3 deluxe board is a 500ma slow blow, just in case anyone wants to upgrade the fuse.
