WarrenR
- Mar 22, 2011
Has anyone tried this with the Dacmagic??
Any thoughts?
Cheers.
Any thoughts?
Cheers.
I have discovered some oddities lately. I was re-arranging my ‘office’ at home and moved my gear. Now it’s closer to my desktop computer than where my laptop sits so I plugged it into the desktop for the heck of it. It got better. My initial belief is that the usb ports on my laptop are underpowered. It made a difference which actual port I used on the laptop. I sometimes heard some low level crud when I played music at 24/96. I would sometimes get dropouts. On my desktop, I can hear no difference if I use the usb galvanic isolator dongle (both data and power lines). Switching cables seems to make no difference. No problems. All is well in musicland. I am going to buy a powered usb hub for the laptop and see if it makes a difference.
In the meantime, I cannot tell if it’s the asynch or coax instead of usb in my dac, but the v-link has made a nice improvement. Ideally, I would have a one box dac with asych (to i2s) and galvanic isolation built-in, but where’s the fun in that? Waiting for perfection isn’t really Head-Fi-ish is it?
Thanks for the report. I look forward to what the powered hub does. Which one are you getting?
Quote:.....hands down from the first note.......
The review of the V-Link by Stereophile is now available on line
http://www.stereophile.com/content/musical-fidelity-v-link-usb-spdif-converter-0
I just got an Audio-GD DI this past weekend. I tried out the V-link briefly a couple weeks ago. Unless the V-link does a lot of break-in over time, I thought the DI was better hands down from the first note. Not to say the V-link performed badly, sounded fine. But paying the same for a DI is a no-brainer.
